It was pointed out to me by my pool plumber that my pool panel is not up to code. The panel itself is fine, the way it is wired up is not.
The panel is fed by a 30A DP breaker in the garage. The wire is #8. There are two circuits wired to this panel, a 15A for the pool vacuum/cover pump GFCI recpeticle, and a 15A AF/GFCI breaker for lighting 15' from the pool. The pump is on a separate 30A DP breaker in the garage, wire to a timer that controls the salt cell and a DPST switch for the pump shutoff. The panel is grounded to a ground rod next to the pump pad, and the equipment is properly bonded as well.
Pool plumber says I should have the panel fed from a 60A breaker in the house, and the 30A DP for the pump and timer should be in the panel poolside. The conduit under the concrete is 1" PVC.
What should I do?
What should I do?
