In order to conceal plumbing in my basement, I framed a wall about 8" off the foundation slab. Unfortunately on that same wall, we have stairs leading to the outside (covered by a bulkhead). Rather than leave the door recessed 8", I'd like to sit it in the new framing, creating a seamless look.
I figured to close off the bulkhead to behind the wall, I would run plywood from the framing and attach it to the concrete (the last thing I need is water or pests getting behind my new walls).
I was originally going to use construction adhesive to attach the plywood to the slab, but I realized I have to be concerned about water wicking thru the slab into the plywood.
So I'm figuring I could just wrap the backside of the plywood with some 6mil plastic and tapcon it in?
Or would sill-seal be a better option? If I go with sill-seal, can I sandwich the sill seal between construction adhesive and the plywood, or would the adhesive eat away at it?
