Any ideas on how to best attach plywood over windows on a Barndominium?
Steel structure
Thanks
Steel structure
Thanks
Ok, will post pics when I get to the house. Sorry should have thought about that. Will be a little laterPictures, absolutely. Whatever you install will be permanent, since it is a steel structure. Think about shutter dogs and the like. I am sure we can find a means to do it. Post pix.
Speaking of shutters, why in hell don't the folks in hurricane prone areas install shutters to protect windows. Can humans get more ignorant than that? People living in rain prone areas don't take their gutter down after each rain and pitch those in the landfill.
So in summary, it's back to " it just can't get much more ignorant than that, and we could probably safely add stupid to the description " as to why there is always a shortage of plywood, it's expensive and the landfills are full of it.
I suspect you storing those is an exception rather than the rule.:thumbup1:Well I am sure Home Depot loves it.
I think if the cities allow incremental install of shutters and impact windows and doors it would make a huge difference.
Plywood itself is not bad though you just have to reuse it. I have a few windows at a property that use plywood as shutters, I had hanger bolts on them spaced evenly and the plywood has predrilled mark holes I just put on and fasten with wingnuts. I don't care if it warps a little and I store them in a shed.
Not a bad idea. Doing the rubber plugs nicely could be a challenge. Probably you could find a decorative screw and rubber washer to put in there until the weather turns bad. Fixed bolts in the wall would be easy to seal with caulk, and loading the plywood would be easy, but more visible from the outside.What I am thinking is securing nutplates to the back of the C perlins inside the channel. Then on the outside would plug the holes with rubber plugs to match. If a storm comes remove plugs and install bolts into precut plywood.
