I have a home in Calverton Li - use primarily Spring/Summer/Fall for long weekends - typically j2 of us there
home was originally one level - 2nd floor added and 1st floor remodeled
long before I purchased
I have noticed that when someone flushed toilet on 2nd floor
bubbles come up in the 1st floor toilet
I suspect the upper floor bathroom - which is on exterior wall opposite the 1st floor bathroom is not vented - cannot see any vent pipe thru roof on that side of building
also I cannot see a vent pipe for sink trap on first floor kitchen
In the basement where the drain pipes converge from the upstairs bathroom, 1st floor kitchen and 1st floor bathroom to the main cesspool pipe there is a pvc pipe that connects to what appears is a vent stack -
that pvc pipe is before the drain pipe from 1st floor toilet/bathtub/sink enter the main drain to cesspool
Plumber has come in and recommended extending a 4" pvc pipe from the area where all the drain pipes converge horizontally to side of building as additional venting
I asked if that would satisfy local codes - assured me it would
do I really need to get this fixed?
is the solution proposed by plumber appropriate?
would appreciate any comments/suggestions/
Thank you in advance tom Sheridan
PS - attempted to post photo of area in basement where ipies converge but had problems with e-mail - will try to attach later
