1 - 14 of 14 Posts
My plumber drilled a hole through a header in our master bath to route some plumbing. When I saw it, I immediately became concerned about the integrity of the beam, particularly since that's where a freestanding tub is going.
Can anyone chime in as to whether this is okay?
Thanks
#1, That's not a hole, it's a notch.
#2, Hard to figure out exactly what where looking at, is that picture right side up in the picture?
As a general rule to meet code it should have been a hole not a notch, not within 2' of the end, and the hole should be no more then 1/3rd the size of the board.
The reason notching is not allowed is where that 90% corner is it causes a weak point where it will crack.
Sorry, I flipped the pic so it's right side up.
I guess there's two concerns, one being the notch, but the other is the hole to the side of the notch where the measuring tape is.
I wasn't actually as concerned about the notch in the joist. But maybe I should be?
Discussion Starter · #6 ·
Any clarification would be great since I know very little of all this.
After some further research though, it appears as though the hole I was concerned about isn't actually an issue.
The real issue as pointed out is the notch. That header doesn't look to be too long so I think I'll have to look in to replacing it then having a hole not much bigger than the diameter of the drain drilled through.
Thoughts?
· Premium Member
It looks to me like the header length is 16". What is it supporting?
Sent from my SM-G970U using Tapatalk
Given the position of the notch so close to the end of joist/beam, it may not be a problem, unless it's supporting a big concentrated load.
The hole in the header may be a little big, but assessing whether it might be a problem would require more info on the framing system
1 - 14 of 14 Posts
