Toilet Waste Drain Problem
I have done my share of very basic plumbing in the past. I was swapping out a toilet today due to repeated clogging of a builders grade toilet. This is a newer house I recently purchased and the plumbing is drastically different looking than anything I have seen or worked with before.
I am specifically interested in the drain configuration for the toilet waste pipe.
After removing the toilet I noticed this waste pipe configuration I had not seen before when removing toilets. I feel like this drain configuration would be set up for routine clogs.
Can anyone shed some light into whether or not this is correct plumbing or if this is the actual issue vs the toilet? I dont want to reinstall the toilet if this will continue causing issues.
The primary issue we saw was routine clogs which were easily cleared with a plunger. There is also a stand up shower adjacent to the toilet which occassionally has toilet odor coming from the drain.
This will not add a photo to the text since this is my first post but the photo is available in my album to the left.
Thanks everyone!
Thanks everyone!
