And how did he check it?
What is the drain made of?
Thats about itSo with it being a drain line that is not under water pressure, is there an easier fix then breaking up the slab to get to the broken pipe once its located, or is that the only fix.
I'm not sure how one would pressure test a drain pipe that has a supposed leak in it.The pipe for the drain is pvc. I am currently trying to get the layout plans on the plumbing from the city I live in but not sure how long that will take and I contacted the home builder and being the house is 8 years old they no longer have the plans they say. As for the plumber, I was not here at the time, but he used his audible tester, and also tested the pipes with air or something that put 100 psi in the pipes to detect a leak, but no video check.
If your sink drain is working properly, the dishwasher pump will not pressurize it.well what I have done is run the sink water on full for about 30 minutes with no leak, I was advised that there is not enough pressure doing it that way to get the leak. Maybe filling the sink and letting it out would prevail different results. And yes I did pay, he did spend almost 3 hours at the house looking for the leak, the dishwasher conclusion came after he left and about two weeks worth of detective work.
