Ok, I'm new to this, but could use some help. My kitchen, 1/2 bath and utility room feed into a main drain line that runs through the basement to the wet wall. Last year I finished that part of the basement and put up drywall, and the drain line runs behind the drywall. Today the carpet around that wall is soaked.
This happened once before when the plumbing got backed up due to a clog somewhere in the line. I assume that there is a leak or two at the top of the pipe, which only becomes a problem in the case of a clog. At that time, the sink itself got backed up and I took care of it with a plunger - clog dislodged, drain pipe emptied, leak disappeared. (Surprised it as so easy!) If that's the only problem I'm inclined to let sleeping dogs lie - after all, to access the pipes I'll have to tear out that whole wall.
Now this time I'm not sure what the problem is. I don't KNOW if there is a clog somewhere - the sink is not backed up, at least not yet, though this could come later. Maybe it's just the leak at the top, which will go away when the clog goes away. I'm deathly afraid it may be a new, active leak.
Is there any way to solve this problem that doesn't involve accessing the pipe itself, i.e. tearing out my whole basement wall?
Any help is appreciated, thanks.
