I bought a unfinished log cabin kit home and need to install indoor plumbing for the wife. It is in North Carolina which uses IPC. We have already had a 1000 gallon septic installed 15 feet behind master bedroom of the home. It is one bedroom and one bath downstairs with a full width 14 foot deep loft upstairs. The attached drawing shows only the rear half of the home which contains all the wet stuff. The 2nd story loft is supported by 4x10 beams on 30 inch center, with 2x6 tongue and groove flooring. The tub shown on the attached drawing is to be a center drain shower.
By nature of being log walls and open beam ceilings, venting of fixtures is a problem. I concidered running the stack up though the plumbing wall by the tub but this puts it out in the middle of the loft floor, and a long way from the kitchen sink. Can I possibly run my drain system as shown, with only one main vent stack in the corner of the kitchen. Also, is it a really bad idea to have the building drain turning 135 degrees?
In the future we will probably add a 1/2 bath upstairs, which could be a 3 inch stack vertically down through the plumbing wall installed by the tub shown and tied in to the building drain where ever appropriate and joining the through the roof vent in the attic. Did I totally miss the boat on this one? Thanks for your feedback.
