10 years ago I had the (original 1963) furnace replaced. Installer did not install chimney liner. As a result... (See attachments.) 3 years ago I had a liner installed. Unfortunately, the damage has been done.
I have been informed that removing the chimney is an option. Cost is a HUGE factor. To tear down chimney and rebuild the cost is $2700. The furnace is 10 and hot water heater 7 years old.
I've learned a high efficiency furnace is necessary to remove the existing chimney.
The questions?
Do I need to replace the water heater?
What is a reasonable cost to replace/repair the affected roof area? (roof is newer 2006)
What is a reasonable cost to replace/repair the gutter/soffit?
What is a reasonable cost to replace the brick work?
(brick cannot be matched) suggestions for visually pleasing options?
Can ventilation be run through the currently affected brick area?
Do I start with HVAC tech or general contractor? If not...
Should I subcontract?
Are there other things I should consider?
I'd really appreciate feedback!
The questions?
