1 - 8 of 8 Posts
Hi
I am replacing an in sink erator & need some help with splicing the plug I cut off of the broken erator onto the new erator. There are 3 wires comeing from the plug I cut off of the broken erator, the middle wire is green & the 2 outer wires are black. I think the green wire is the ground & I see a green ground screw for it on the new erator. The 2 wires coming from the new erator are colored white & black. Can anyone help me with which of the black wires coming from the plug I cut off the broken erator goes to the white wire coming from the new erator & which black wire from the plug goes to the black wire coming from the erator? Thanks
· A "Handy Husband"
Your confusing me but:
green wire from cord to green ground screw on GD
white wire from cord to white wire on GD
Black wire from cord to black wire on GD
Reactions: dommm
Discussion Starter · #7 · (Edited)
The conductor on the ribbed side of the cord is the white.
Thanks for that info Jim Port.
PS: Just to confirm, in the bottom pic of the wire that I posted above, is the ribbed side on the left of the wire & in the middle pic is the ribbed side on the bottom? Just checking to make sure I'm understanding you. I'm likely being a bit paranoid but I hate working with electricity until I'm sure of what I'm doing. Thanks
1 - 8 of 8 Posts
