I own a 4 bd/2ba single family home in Southern California on slab foundation and iron plumbing. It was built in 1963. When I purchased it 2 years ago owner told us that she would do hydro jetting to remove the roots from the sewer mains every year. She did this just before we bought the house i.e. 2 years ago.
Since beginning we have no problem in the bathrooms but the washer drain would keep overflowing off and on. We will snake it ourselves and it will be ok for a while and it will start again. We've been dealing with this for a while but this weekend on top of the usual overflowing from drain pipe the black dirty stuff came out of the bathroom tubs and the toilets won't flush anymore. We called plumber and he snaked the main line and his tool broke but he took out a very long hairy looking roots. He said he can't push further and has to hydrojet. Hydrojetting cleared the mains and the cable went all the way to street. Toilet flush, bathroom sink etc worked again.
Then I put a hose pipe in the washer drain and the water came out. Then he put a camera in and he found water stuck in it. He snaked it and snake went all the way through but didn't bring out anything except black sewage that was stuck to it. Then he asked me to turn the kitchen sink at full speed and he saw water coming near the base of the washer drain.
So basically hydrojetting fixed the main line but we still have thick black gunk clogging the kitchen/washer drain lines. He is planning on pressure cleaning it tomorrow. He said the washer drain is going to be a ongoing problem as the new washer drains too fast.
1) Any idea how to permanently solve this problem ?
2) Is pressure cleaning pipes going to solve it ? Can I do it myself on regular basis ?
3) Can this be a vent issue ? I know for sure that nobody has looked at the vents for the washer/kitchen drain till now ?
4) Can the dishwasher and washer soap be the culprit for this build up ?
5) If we have to replace the pipe how can this be done as they are in foundation. What are approx. costs ?
6) The previous owner had the washer drain into a large sink next to the washer. We removed the old sink and connected the new washer directly to the drain pipe. Do you think that using a sink is better solution which will allow water to go through the drain a bit slowly ?
7) Some people recommend using a drain cap to prevent the overflow from washer but wouldn't that just shift the problem to my kitchen sink then ? Also this can cause siphoning.
