Last year, I purchased a home that has a covered patio.. The cover consists of a lean-to, and it's sagging about 1" or so over a 12 1/2 ft span.
The roof pitch is right at 1/12.. so, it's pretty flat.
The span is 12.5ft, from where it attaches to the house, to the header. The span is composed of 2x6 pressure treated pine (not sure what grade), on 16" centers.
The cover is 15ft wide, with (3) 4x6 posts supporting the load. They are 7.5ft apart, and have double 2x6's nailed/glued together as the header. There is no evidence of sagging with the header.
The roof is 15x32's plywood, with a layer of tar paper, and shingles on top of that.
Everything that I've read, says that 2x6 pine should be fine for this on 16" centers with a span of 12ft. Why is this thing sagging so much? It's only 2 years old.
More importantly.. what can I do to fix the problem? I'd like to close the patio in, and put a ceiling in place, so going with 2x8's or bigger is out of the question. There simply isn't enough room overhead. Can I jack up the roof with bottle jacks, and nail/glue another 2x6 onto each existing one? Will this be enough support? Should I use a different type of wood?
Any help would be appreciated.. I don't know a great deal about the math involved.. but, I am capable of using a saw, hammer, and a nail gun.
Travis
Travis
