building a saltbox roof. front pitch is about a 12 and rear is about a 3.5 just for example. the rear run is going to be approx 18ft. i was going to make trusses out of 2x12x20. ridge beam a 2x12. i was thinking since im putting 2x12 i can safe money and not put ceiling rafters in and make a cathedral ceiling. should i feel comfortable with that 18ft span on the back? say i would go 16'OC. what would be the most cost efficient way to build this in the long run. not sacrificing building safety? even if ceiling rafters could be used. thank you
