Use a good miter saw and cut inside and outside meters. I don’t understand the problem.
I think . . . you are talking about the apron molding underneath the wall cap, using the same profile but being turned "upside down", and how that will be mitered where it meets the upper casing coming down to this wall cap.
Here is a better solution, extend the cap. Also a plinth block would work.
I seem to remember you were doing some wainscotting, doesn't that affect all this trim anyway?
If you're open to opinions, mine is casing the lower wall end would look out of place. I'd have it just like the pic I included. Both drywall or wood will get banged up and need filled either way. If you want it for ornamentation, where more would match the style of what you're doing to the rest of the house (and wainscot if you do some anywhere), then I would do a faux column.I'm going to want that exposed jamb trimmed, so whatever I use as the apron would have to be used to case the portion of the wall between the ledge and the floor.
