1 - 15 of 15 Posts
I have tried to use the online wire sizing calculators and charts to determine what I am going to need and found that almost every calculator/chart gives a different answer.
120 Volts
Single Phase
Distance: 65 feet
Will be in conduit buried 18 inches
From the many calculators and charts I seem to be leaning toward these sizes and types for the following 3 loads...
1. 100 amp - #3 AWG THWN copper
2. 60 amp - #6 AWG THHN copper
3. 30 amp - #10 AWG THHN copper
Does the sizes and types look OK?
· Union Electrician
Yes. Some may say you'll need to bump the wire size for voltage drop, but IMHO I think those sound good. Assuming you are talking copper conductors.
Now don't forget about equipment grounding conductor size, and your pipe fill.
I meant to type THWN for all of those. I'm glad you caught that. Those where copied and pasted directly from the shopping list I'm making and it was wrong there too.
1. 100 amp = #3 THWN copper
2. 60 amp = #6 THWN copper
3. 30 amp = #10 THWN copper
4. Ground = #6 THWN copper
PVC conduit, 40% fill, two 90 degree bends = 1 inch minimum. I'll go with 1 1/2" for easier pulling.
Go 2 inch in case you ever want to remove the wire and upgrade. The expense is the trench. The difference in pipe costs are negligible. Always go bigger with the pipe. Always.
· Licensed Electrical Cont.
Where could you possibly need 30, 60 or 100 amps at 120v???
If this is for a feeder you can and should use 240v for your calculations.
I agree, 65' is not even worth thinking about VD.
Are you saying you want to install ALL three of these circuits in your conduit, or that you are going to choose one from the list?
What is the circuit(s) for?
is wire size right for load/distance?
IMHO the wire size/load calculations are correct. But adding in the other factor; Namely, distance. Even though the presented sizes are correct. But raising the size (AWG) (this is the funny thing about AWG. The higher the # the thinner the wire. Actually, it's not humorous at all. There's a logical reason for it. The gauge is measured from the outside IN. Therefore, the closer to the core, (higher #) the thinner the wire.) will increase performance, due to Voltage Drop!!!
[Correct] wire-size? loads/VD
You're right that 'feeder' calculations should be @ 240V. And @ 65ft., VD is not a major factor. But for individual loads the wire sizes are correct (theoretically). As far as increasing wire size; Even though Voltage drop is not a major factor @ less than 100ft+, still, it would improve performance! Again, the examples given here are mostly theoretical. With very little practical application!!!
IMHO the wire size/load calculations are correct. But adding in the other factor; Namely, distance. Even though the presented sizes are correct. But raising the size (AWG) will increase performance, due to Voltage Drop!!!
You really believe this at only 65 feet?
· Banned
From Wiki
"Increasing gauge numbers give decreasing wire diameters, which is similar to many other non-metric gauging systems. This gauge system originated in the number of drawing operations used to produce a given gauge of wire. Very fine wire (for example, 30 gauge) requires more passes through the drawing dies than does 0 gauge wire"
Discussion Starter · #13 ·
The wires are to be hard wired to a deck oven. The oven has two parts, an oven and a proofer.
Oven
240 volts
12250 watts
51 amps
Proofer
120 volts
2960 watts
24.6 amps
One hot needs to be able to carry 51 + 24.6 amps = 75.6 amps
One hot needs to be able to carry 51 amps.
The neutral is only used in the 120 volt proofer part of the oven which runs at 24.6 amps.
Then the ground wire for the entire thing.
1 - 15 of 15 Posts
