I have a circuit feeding the kitchen that feeds a two-gang box above the counter near a sink, and that box feeds a small fluorescent light above the sink, and a clock plugged into a clock hanger receptacle. There is nothing else on this circuit. The box contains two devices, a duplex receptacle (tabs on both sides NOT broken), and a combo switch and ungrounded two-prong receptacle. Neither is GFCI. The combo switch only controls the fluorescent light; the combo receptacle is always hot.
I want to replace the duplex receptacle with a duplex GFCI receptacle, and replace the combo with a non-GFCI grounded combo and feed it from the new GFCIs load terminals, so it too will be protected. The clocks receptacle will also be on the GFCI's load.
Attached are diagrams of the existing setup, and my proposed new setup. These are the first diagrams I've ever done, so hopefully they make sense.
Two notes on the GFCI: For the purpose of making the diagram easier to make, I reversed which side of the Leviton GFCI the hot and neutral wires go to. Also, I'll be back-wiring the GFCI - there are two slots in each position, for up to two wires in each position.
I'd appreciate comments on my proposed new wiring setup. I'd also appreciate comments on the diagrams themselves, such as how I might make them more understandable.
Thanks.
Thanks.
