My finished basement space has always been cold, much colder than I believe is appropriate. Think I've found the issue. There is significant cold air infiltration coming through the main breaker box. I'd go check the outside to see if there is a hole, which I suspect there is, but it's 4 degrees atm...
Anyway, for a temporary fix, can I place a piece of saran wrap over the panel door to stop that air from spilling into the room? I won't be touching anything inside of the door panel next to the breakers, just on the outside of the door. I've already added some caulking around the edges of the panel which helped, but the air is just coming through the edges of the door. Thanks.
