:vs_worry: Come Fall usual routine with Darfty Windows to install Plastic to cut down heat loss.. Have an older home built in the 70's that didn't come with Exhaust Fans Kitchen & Bathroom.. Consequently Condinsation Issues in the Bathroom.. If I had the Techno Where with all to Post a Picture to aid my discription of my query..lol..
Curious where the Condensation is going ?? Previous to putting plastic up the Condensation would pool on the window sill , if it wasn't wiped off it would run down the wall.. The Window is an Insert / Crank Style.. There is about a 3" Sill / Boarder around on the inside.. I installed the Plastic on the outside edge of the Sill.. The window has to be a good 20 yrs old, there is a small amount of Condensation that will still pool at the bottom of the window but only on the window frame itself, no condensation makes it onto the sill.. My Query is , any idea where the moisture is going ?? If the moisture was collecting on the Sill I know it would have to be leaking down inside the wall.. :vs_cool: Thoughts Appreciated , Cheers Thanks
