I currently have carpet in my 1998 home. The carpet needs replaced, and I have many squeaky spots and a few uneven spots. I am planning on installing laminate in the entire upstairs level. How would I ensure no squeaks or uneven spots return?
The poster is on the second floor, no access from below. The best he can do is screw it down. He needs to address the unevenness.just get a screw gun and construction adhesive....one person walks on the bare subfloor looking for squeaks, and has the screw gun and screws, the other person is in the basement if its not a finished ceiling, with the adhesive, when you find a squeak, pump some adhesive along the plywood and floor joists from below and screw the plywood from above, squeak problem cured, for the uneven areas, either fill in with some leveling compound or use a belt sander to even it out...
read post #4The poster is on the second floor, no access from below. The best he can do is screw it down. He needs to address the unevenness.
