Ok so i have attached a pic of my basement floor plan.
As you can see i plan on finishing an area of 23 ft wide by 13.4 ft long.
The dark black rectangles represent the 3 windows in this room .
Now this space contains 3 exterior walls. Last wall has opening connecting to existing basement and sharing a wall with garage.
So using the regular formula for baseboard watts x 10 , i need about 3000watt heater.
So i was thinking of 2 baseboards of 1500 w each or should i go 3 of 1000 watts .
My questions are the following , where would you put the 2 or 3 baseboards ?
Usually they go under the windows, but my 2 windows in the 23 ft section are 6 ft apart and not really centered on that long wall ...not sure if the baseboards there would look awkward or should i put them somewhere else.
My only opening in this space is the 4 ft opening you see.
I would like a nice even heat in there.
I was 1st thinking one on each end of opposite walls , but not sure .
What would you do or recommend ?
Also is 2 baseboards of 1500w better than 3 baseboards of 1000w for an even heat ?
Thanks again,
Matt
Thanks again,
Matt
