Hi! I am trying to renovate our 1963 split level (my wife is about to pull her hair out because we can't move in yet) and am wondering about the feasibility of replacing this stack and plumbing with PVC from the roof to just above where the white pipe is in the photo of lower level.
I am installing a stackable washer and dryer on the floor directly above the cast iron with the white pvc attached to it, and have no drain. The 2" PVC shown is going to a new Kohler Bellwether tub I'm putting in, and I don't think adding a washer drain there would be wise. To the left of the white pipe there is another 2" drain pipe behind the water heater going through a hole in the cement block there, but that would make for a really long washer drain pipe.
The main reasons I'm considering replacing most of the cast iron is that, even though we are not currently using it, I see rusty drips on the lowest floor directly beneath the stack (rain?) Both bathroom toilet flanges in the cement floor (I removed 2 tons of concrete and tile) were rotted, and all drain plumbing in the back to back bathrooms has to be replaced. Some of it has been. As you can see, I've stripped the walls, and don't want to re-drywall them until I have made a decision on this.
Thanks for any replies!
