1 - 6 of 6 Posts
I have a 1971 3-bedroom cape with the infamous AL wiring. I was in the process of replacing all the AL wiring throughout the entire house but decided not to (way to time consumming). Instead, I am now going to pigtail all house receptacles and use the expensive purple caps. Question is, should I followup using the same process for wall switches, ceiling light attachements, and circuit breakers as well? Not sure how far an electrician would go in correcting this issue short of replacing the AL wire with CU. Any comments would be appreciated.
· sparky
Yep. Every outlet, fixture, everything. Very specific method for the splicing and materials for pig tailing the AL to CU. There can be no cuts or marks on the AL as it creates excessive heat on the connection. Use the proper compatible connector (Marrette 63?) and the anti oxidant.
For us here in Canada, anyway. Seems to be some insurance co.'s pushin it.
1 - 6 of 6 Posts
