Waste of time, find something constructive to do.I'm a DIY aspiring electrician. I was thinking of pigtailing all of my receptacles so if one goes bad it doesnt knock all the other ones on the same circuit offline. Also, is this allowed in the kitchen with gfci circuits?
If the receptacles are pigtailed the connection downstream is not interrupted if the device screw becomes loose. Only the affected receptacle is lost.I think you meant daisy chaining and I wouldn't bother if you don't have a problem. Very rare for an outlet to go "bad" and "knock out" other outlets if properly wired etc...
The actual GFCI device must connect to the downstream receptacles at the "load" terminals. The devices downstream can all be pigtailed.Also, is this allowed in the kitchen with gfci circuits?
Personally I trust the screws over a wire nut.If the receptacles are pigtailed the connection downstream is not interrupted if the device screw becomes loose. Only the affected receptacle is lost.
