I'm trying to add another receptacle in the adjacent room, for a TV above the fireplace. (FYI: I can get behind the walls, the fireplace is hollow)
I have any outlet in my bedroom that has two wires coming in (one hot and one for the downstream receptacle (or it ties into a light switch) .
My question is should I pigtail the outlet (4 wires, too much? - pigtail, hot, current downstream receptacle, new receptacle) or make it a junction box?
I would make it as a jbox. safety is the key.. then go from there. Is this room down stairs or a single house?
if single house with crawl space.. you can run drill a whole in the wall for the new line.
Go under the house with the new line bring it into the existing box that has power.. back to the new receptacle.
E
ven with a story house with appropriate attic space, I would run a wire from the attic into the wall tying into one receptacle with the power back to the new receptacle in the wall.
Super Moderator
Pigtail it. If you remove the receptacle it might make the room not code complaint. You need receptacles every 12 feet along a wall.
You have three cables not three wires.
