Pictures! Insulating bonus room above garage.
Hi guys. I am about to start on my bonus room over the garage build. I am starting to tackle the insulation. Would you help me with what I need?
Here is the knee wall.
On the backside of the knee wall there is already a cardboard type barrier installed. The barrier is stapled to the studs. Can I use this and just tape the seams up and spray foam any gaps? I am planning on using faced R-13 in the walls.
For where the ceiling will be up against the roof rafter, I plan on using rafter mates for an air channel and faced R-19. I will cover the ends of this insulation (on the knee wall end) with an insulation board and spray foam it around the edges.
Here is the top of the ceiling.
I plan on using faced r-30 for the "attic" section.
Here is the floor.
I could use advice here. How do you recommend I insulate this space? Insulation board on sheetrock then r-30? I plan to seal off each gap between the floor joist with insulation boar and spray foam.
Lastly, am I required to use a vapor barrier in any of these areas?
Here is the floor.
