Hi all,
I tried replacing the original hand-towel rack in my 1/2-bath, and got a wall geyser instead.
The small hole in the pic below is the one I drilled. The two bigger holes are where the original towel rack was screwed in!
The dark spot is almost a decade worth of rust and presumably mineral build up that must have created enough of a dam to keep the pipe from leaking when I removed the original towel rack.
I kind of feel lucky that I drilled into the pipe, otherwise I wouldn't have know about this ticking timebomb.
So, what's the best approach to repairing this?
Does it make sense to buy the tools and parts to do it myself for just this one repair?
Can I just fill the holes with a polyethylene compatible adhesive, such as Tap Plastic's Poly Weld?
The pipe is 1-1/4" Wirsbo, and is the main line. There's an expanded coupling to a manifold a few inches above the 4x4" hole I cut in the wall, and there is a clamp nailed to the stud a few inches below the hole. So, there is very little play in the pipe right now to work with.
For now, I've temporarily patched it with a wrapping of self-sealing silicon tape and a couple of pipe clamps.
Thanks,
Monty
Thanks,
Monty
