Pex Connection to CPVC
1968 Views 9 Replies 6 Participants Last post by  natspawpaw
I will be making 1/2" PEX to 1/2" CPVC using copper crimp rings. Any recomendations on how these connections should be made? I'm looking at using a male pex to a brass female (with rubber washer) that has cpvc attached for gluing.
Is there a better connection?
1 - 10 of 10 Posts
why not just use a 1/2" sharkbite ? have yet to see one fail
bob
I'm a plumber, but I've never used CPVC except to make a minor repair once on an existing system. I'm just curious - why the rubber washer? I know the PEX x male adaptor has a tapered thread (pipe thread), and I would assume the CPVC x female adaptor does also(?) If so, there's no need for the rubber washer - just some teflon tape or pipe dope. Does the washer come with the CPVC fitting, or were you planning to add it?
Edited to add: I just googled it, and saw that the washer is integral to that fitting, so you shouldn't use it with that PEX adaptor. I'd use a CPVC x male adaptor (all plastic):
http://www.pvcfittingsdirect.com/_e...apter_Mipt_x_Slip_PVC_Fitting_Schedule_40.htm,
and a 1/2" PEX x female adaptor (brass):
http://www.pexsupply.com/Wirsbo-Upo...ass-Female-Threaded-Adapter-1-2-PEX-x-1-2-NPT
Sorry to say, I feel in a diy situation a sharkbite is going to be the way to go. Plastic to brass leaks all to often if not done properly, which can be tricky.
And they tend to crack down the seam on the sides of the fitting.
Why not buy a cpvc x pex adapter. They do make them
Sent from my iPhone using DIY Forum
Reactions: 2
Nice! Just googled it:
http://www.siouxchief.com/Supply/Fitting-and-Valves/CPVC/CPVC-Adapter.7X8VK
That'd be the way to go.
I didn't know such a thing existed. Exactly what I need.
Thanks
Are those sharkbite fittings really reliable? And if not for cost would you use them instead of copper crimps on pex?
1 - 10 of 10 Posts
