1 - 1 of 1 Posts
I'm running pex water lines within an indoor baseboard chase. I'll be insulating the hot lines with foam tubing to retain heat, but was wondering if I should also put foam tubing on the cold lines to prevent any condensation.
The chase, being open where the lines enter/exit, will allow room air to circulate somewhat through the chase, so I was wondering if any moisture in the air will condense on the cold lines and cause dampness within the chase.
Arky
1 - 1 of 1 Posts
