I'm planning on replacing the 2x2s on my patio cover. The patio is 16' x 42' and I estimate I will need about 1500 linear feet of 2x2s. The joists are spaced 24" oc and there is an over hang on the ends.
My problem is this was originally built with 2x2x12 but I can't anyone that has 12' only 8' which means more waste. Currently the 2x2s butt against each other on top of a joist. So they tend to curl up and warp. I do get snow, wind and rain.
I would prefer to switch to aluminum but my wife is adamant the rain will make noise on the hollow aluminum outside our bedroom.
So is the questions are;
Is there a way to end join (between joists) the 2x2s or just cut them
shorter and end over a joist? Nails/screws on the very edges of the 2x2s.
Wood choices are, priced highest to lowest. green heart redwood, kd ceder, "sever weather" treated from Lowes, or fir from Home Depot. Priced highest to lowest. I plan on painting it to match the house, elastomeric.
Thanks
https://www.dropbox.com/sh/e3p7g0nug8rptq6/AABrbeEiuGAacFArByFdNGUya?dl=0
Thanks
