Hi, I'm trying to get an old air compressor going again, but when power is applied, it just hums. I've checked power and 220 is on all 3 legs at the switch box. I can easily rotate the pump and motor by pulling on the belts so I don't think I have any bad bearings. I'm thinking the centrifugal switch is bad and wondering if someone can tell me if it is located on the end in the attached picture. If so, will removing the 4 screws around the round cap allow me access to it? I'm afraid if I take the cap off, I may end up with more problems... The specifics of the old motor are:
Peerless, 5 hp, 1750 rpm, 40 c(?), 3 phase, 200-440 volt, 60 hz, 13-6.5 amp, CON duty, Frame PH254, Serial 403257.
I'd greatly appreciate any help. Thank you in advance! Pat
