Peeled Paint
950 6
I have two large areas of paint that have peeled off down to the drywall. I am planning on repainting the whole wall a different color soon. Should I peel off the rest of the paint and start fresh or should I just sand the edges of the area and paint over it? Any other advice or ideas is appreciated. Thank you.
1 - 7 of 7 Posts
To better answer the question, more "paint context" info. is needed....
What kind of room-use will this be?
Age of home and/or the rooms walls?
Are the affected areas on an outside wall?
Upper or lower-level?
Has wallpaper ever been used/removed there?
Faron
Thanks OM10!
Couple more questions....
Is the peeling on an exterior wall?
Is it a full basement?
If not an exterior wall, what's on the other side of the peeling area(s)?
Has the whole wall been moisture-tested with a surface-reading scanner?
Faron
I'd get the walls scanned first.
Did this happen after a period of rain?
What area of country are you in?
Was drain-tile used around new addition?
I'm just tryin' to find out if this MAY be an exterior moisture issue!
It could be as simple as - that area of wall wasn't cleaned well (dust left behind, etc.) before painting!
Faron
1 - 7 of 7 Posts
