Cross-posting this here because maybe you guys have a better understanding of the situation.
I'm on the verge of going totally bonkers. Days turned into weeks and weeks turned into months and I still cannot understand why this is happening nor can I prevent it.
I live in a house that was built within the last 10 years. As mandated by federal law, it has AFCI aka Arc Fault Circuit Interrupter breaker system. It's rated for 15 amps on every wall outlet circuit.
My computer will run just fine when not doing anything graphically intensive. When either I try to play a game or do GPU rendering for the filmmaking that I do, it will trip the breaker without fault either immediately or within 15 minutes. Initially I went around this by using EVGA Precision to lower the "power target" on my GPU. That seemed to work but as time went on, I had to lower the power target more and more. Now if I boot up Black Ops 3 or Red Orchestra 2 or anything really, the breaker will trip within a few seconds.
I've done a lot of research and after contacting several electricians, they recommended I purchase an Isolating Transformer to cut down on the line noise that is causing all the "nuisance trips" in the AFCI breaker. Today I got myself a Topaz Line2 1000W/8.3A power conditioner to see if that would help. Unfortunately it seems to not have the mettle necessary to even power my monitor, as both my monitor and PC run momentarily under its power before the device resets.
I had built the PC only a few months prior to moving here and there we no issues before. Everything is no more than 7 months old. The PSU and GPU are brand-new. I thought replacing them would stop the breaker trips, I was wrong. I am convinced there is nothing wrong with my hardware as it works flawlessly away from home.
Now I am at an impasse: either sink more money (well over $250) into a more modern Isolation Transformer in hopes that it will be able to power my PC under full load, or effing move because I am AT MY WITS END RIGHT NOW. This has caused a considerable amount of problems in both my studies and my gaming. I am desperate for a solution. PLEASE help me.
MY SYSTEM:
Corsair CX-750M PSU
EVGA GTX 970 FTW
12 GB DDR3 RAM, mixed PNY and Patriot in dual-channel
Asrock Z97 Killer mobo
i7-4790k @ stock clocks
PNY 120GB SSD
NZXT S340 Case
LG 1440p 21:9 monitor
MY SYSTEM:
Corsair CX-750M PSU
EVGA GTX 970 FTW
PNY 120GB SSD
NZXT S340 Case
