Paver Base Material
37159 Views 6 Replies 4 Participants Last post by  High Gear
Hey everyone,
I am getting ready to build a 15 x 18 paver patio and I am trying to figure out what the best paver base material to use is. I keep getting conflicting opinions from local gravel suppliers. Some tell me to use 1 inch minus some tell me to use screenings which is closer to 3/8 inch minus. Both claim that they pack better than the other so I am trying to figure out what is correct. Please advise.
Thanks!
1 - 7 of 7 Posts
Crushed roadbase gravel 3/4 down to fines ( dust) , !" down should be fine.
When you vibrate compact , you need to use enough water that it will take
on the consistency of cement. ( to much and your compactor won't go
anywhere , you will figure it out withsome practice ).
The water forces the air out ( you'll see it bubble even ) and allows the
gravel to lock together more easily.
Do not put concrete under a typical paver patio instillation unless absolutely necessary. Just a uniform,uncompacted 1" setting bed of clean concrete sand over a compacted road base material. Work fine sand into the tight joints between units.
For the thinner, less stable type of larger pavers - "stepping stones", slate, concrete slabs, etc., the requirements may be different to minimize joint/unit heights and cracking of the paving units.
Dick
Huh ?
You may wish to reread ...I was describing how " mushy " the gravel with
water can get . ( it will take on the consistency of cement )
I'll rephrase ...1" IN DIAMETER down to fines would work , I can get 3/4 DIA and down here
A 6" depth of base material is minimum in my area , I have heavy clay in my
yard so I went beyond 6" in depth .
Discussion Starter · #6 ·
Thank you for your help everyone! I only seem to have the 2 options: Option 1 is 1inch minus and option 2 is what everyone seems to be calling "screenings" which one place told be was closer to 3/8 or 1/2 down to fine dust. Where I live it seems to be the norm of a minimum of 4inches of base and 1 inch of sand. Concrete sand or coarse sand is what i have been told to use. Then to come back with a polmeric sand into the joints. My main concern is trying to figure out which size base material to go with because I have called 5 different gravel/sand suppliers and everyone has a different preference on what to use.
1 - 7 of 7 Posts
