I am looking for some advice. We have a small "starter home" in Michigan. The previous owners had installed a brick paver patio and sidewalk that was buckling, rippled, and loaded with weeds. Last weekend we pulled (about 2,000 brick) it out thinking that we would re-lay it ourselves. Then we looked into the process and it seems like A LOT of work. Looks like dig out the area (approx 400 square feet) down about 6 inches, cart that dirt out, bring in several inches of crushed limestone, cover with slag, make sure it is level, lay out a border to hold pavers in, re-lay the pavers and fill cracks with polymeric sand several times and hose down. I am pregnant and not able to do a ton of the heavy work (don't really know how much use I would be even not prego) so that leaves the heavy lifting to my husband. First off, I am wondering...is this realistically a diy job? There will be a lot to coordinate with delivery of limestone and slag, perhaps renting a mini excavator.
What concerns me the most is that I have been researching all of our options and it seems there is no perfect solution. If we want to re-lay the patio, it is likely that we will eventually run into some of the same problems we had before, poured concrete will likely crack and it sounds like ground level decks are prone to rot. I know there are some large tree roots in the area as well that we would either have to work around or dig and cut out.
I am not too interested in stamped concrete for two reasons - first I think it might look a little out of place with our starter home, and second I have read it is likely to crack and although it would be an annoyance with poured concrete it would be devastating with stamped.
I do have a quote of $3750 (using existing pavers)from a local landscaper. Although he promised to do a good job, he made it clear that there was bound to be some shifting over time and that although no one else would tell me that it was the truth. Is this inevitable?
Any input would be much appreciated. I am kind of at a loss at this point.
