Not sure if this is the right forum but I have a couple questions about my patio overhang.
First, it's in dire need of cleaning (been getting worse and worse since I moved in). Hosing it down from one of the 2nd story windows or from a ladder only gets rid of the leaves & twigs but isn't nearly powerful enough to clean the panels. Definitely needs a good hand scrubbing. Looking at the pictures, should it be OK if I get up there and do it myself as long as I keep my weight in line with the beams? I'm about 220 lbs. Any particular cleaning solution I should use? Otherwise I'm just thinking diluted dish soap.
Second, it needs patching in a couple locations (leaks). Here's one of the leaky spots (shot from above):
Looks like a triangle shaped piece of one of the panels has been knocked out right at a seam. This is the worst of the 3 or so leaks. I was hoping I could just use a rubber sealant (e.g. Flexseal, Leakseal), spraying it on liberally from above (although making sure you can't see it from the bottom) and see how that holds. Stupid idea or give it a shot?
(yeah my siding probably needs cleaning too right?)
