I am looking to build a new patio cover to shelter the rear door from harsh New England weather. The house has painted pine trim all over the exterior. The patio cover should also be painted white to match. The 6x6 posts will be clad in white trimboard, so that's no problem, and I will just paint the LVL beam and live with it. But what species would you suggest for the 2x10 rafters, purlins and ledgerboard. Can I use southern pine if all surfaces are painted, or do I need to use douglas fir or cedar?
Also, I think I am using the span calculators right in figuring for 2x10's, but I would love to know if I can use 2x8's for the rafters to lessen the weight. I live in CT. The patio cover will have painted pressed metal roofing panels on the top 10', screwed to purlins. Very little dead load. See attached diagram for dimensions.
Thanks in advance for all replies.
