1 - 10 of 10 Posts
what is the main difference between using the expensive patcher mix (~$15) vs. regular concrete mix ? holes like a ft by a ft.
Discussion Starter #3
deeper than the concrete. maybe a foot or so. will fill with gravel up to the level where the concrete goes.
I'm a bit confused. You've a 1' x 1' wide hole. The depth is "deeper than the concrete". What concrete? How thick is this concrete? When patched, what use will this patched area be for (support for building above, etc...)?
Discussion Starter #5
i wanted to move a sewer pipe by a foot. broke the concrete, cut wire mash, tore foam, dug out the gravel and dirt, got to the pipe, adjusted it.
1 - 10 of 10 Posts
