Hi I just removed by carpet and tack strip. When pulling out the nails that are holding the tack strip into the concete it made shallow holes (< 0.5 cm) in the concrete some small (1cm in diameter) and some big (~1 inch in diameter). I was planning on placing laminate floor in the room. I wanted know should these shallow holes be patched to level the area...or will it not make a difference overall since there is plenty of concrete around it that wood pieces won't really sag in the area.
If they need to be patched will quikrete work well? Thanks for the help.
