1 - 20 of 31 Posts
Discussion Starter · #2 ·
i am experiencing a partial power outage when my hvac unit kicks on . It will not turn on immediately but will cause power to go out in only some of the house. once the unit does kick on the power restores its self what could be causing this problem ?:(
· Electrical Contractor
You most likely have a bad leg on your electric service. This could be anywhere from where your breaker panel is to the POCO transformer. Definitely good idea to get this checked out before it gets worse.
Reactions: bj1
· flipping slumlord
i am experiencing a partial power outage when my hvac unit kicks on.
A few basic questions:
Is this a heat pump as well as AC?
How old is the equipment?
How long has this condition been present?
When was the last time a qualified HVAC mechanic serviced it?
How long sine "Cousin Jerry" touched it?
Discussion Starter · #6 ·
1. yes
2. 6 1/2 years old
3. new years eve was the first time it happened
4. in the fall it was serviced year before that hvac company came in a replaced the compressor
5. no cousin jerry work lol
i am experiencing a power outage in only parts of my home. what causes this kind of problem ? Please someone help :( it is so strange no breaker tripped . and the problem corrects its self some times in a few minutes sometimes a few hours. please help me understand what can be causing this ...:( it seems like when my heat and air system kicks on the problem starts then other times it kicks on without any problems . and if the power is out when the hvac system comes on everything else does to .
Call an electrician. We can't go in your house and start checking things to troubleshoot it and based on your wording, I'd guess you don't have a lot of troubleshooting experience for situations like this.
However, start with identifying which outlets are on what breakers, then when it happens you have to isolate which circuits are out and trace back to the feed to find out where the circuit is broken. It sounds like it could be a neutral problem to me based on how little info you gave.
If I was in your area yes I would help but nowhere near you. You have a bad hot leg in your service from the sounds of this when your furnace kicks on if it's 240v then it causes power to go to the rest of the house. Get an electrician ASAP.
Reactions: bj1
This is not a service provider site, it's a site to help out DIY people. He's in New York if you read his location under his name.
Yeah big differences in both areas too. I can't go outside of my area due to licensing and insurance requirements.
· flipping slumlord
1. yes
2. 6 1/2 years old
As mentioned in the other thread start by calling the power company.
Confirm if this recent/sudden problem is outside your house or not.
If that proves to be fine... call a different HVAC contractor.
btw... do you recall why they needed to replace a 5yo compressor last year?
Discussion Starter · #15 ·
the compressor was faulted and still under warranty so it was replaced at no charge. if the problem is at the meter or on the outside line is that my financial responsibility or the power companies ?
Odd that we have at least three differant poster today all having power problums that all could be cause from incoming power and not one registered with there location.
1 - 20 of 31 Posts
