Hello everyone, my name is Ivan. I want to share with you the technology of making a panther out of wire. Its height is 80 cm.
654727
654728
To make such a panther, we will need: a welding machine(normal), a Chameleon welding mask, an iron knitting wire with a diameter of 5 mm (about 10 kg).
First of all, you need to print the drawings to scale. You can find them in my tutorial video on YouTube. They are in pdf format. Then the sheets are glued together into a drawing. And already along the contours in the drawing, the wire bends. Then the bent elements are attached to each other by electric welding.
The resulting panther can be decorated with garlands. It can also be used to create a topiary covered with artificial turf.
You can also make a panther of any size. To do this, you need to change the scale when printing drawings.
Master General ReEngineer
Ayuh,.... Good Job,.....
My Dad made a reindeer for Mom as a Christmas decoration, a lifetime ago,....
