power is off to breaker box so somebody pulled out the whole panel left the bare wire now i want to replace the panel how do i test each switch and outlet to replace breakers with out any power supply
If there's no panel, it's pretty likely it's all dead.:laughing:Double check thats its all dead before you start
..you test them after the new panel is in place. You are going to hire someone to do it, right? If you have to ask how to test switches and outlets you shouldn't be doing it yourself..power is off to breaker box so somebody pulled out the whole panel left the bare wire now i want to replace the panel how do i test each switch and outlet to replace breakers with out any power supply
Why is utility power off ?power is off to breaker box so somebody pulled out the whole panel left the bare wire now i want to replace the panel how do i test each switch and outlet to replace breakers with out any power supply
