1 - 7 of 7 Posts
Using some pancake boxes for the first time. Not much room inside, especially to tighten down the cable clamps. It came with a single plastic "clamp" that doesn't require tightening, but I've got three cables coming in and I think that will only feed one.
I can't get to the clamp screws to tighten it up, and if I rotate it so I can get to the screw heads the other end hits the side. I don't have great access to the attic so I'd prefer to do it from the ground. Am I OK to leave the cables unclamped?
Any tips or tricks?
· Super Moderator
The canopy would need to be marked with its capacity before you could could utilize it for space. A saddle box would give you more room.
Why do you have so many cables in the box?
Discussion Starter · #6 ·
I was just reading up on that part of the NEC and it seemed like that would be allowed.
There's another set of outlets and my entire bathroom that get power from there (it's my master bedroom ceiling fixture). Don't ask me why, it's just what I found out when I opened it up. The wiring here has been a joke so far. It would seem that this would have been the original wiring, but I don't know why someone would do it this way. I was assuming I'd have 1 or 2 cables running to it but also found the third and had to figure out what specifically that powered.
The electrical at this house has been a cluster and I'm slowly trying to get it right (or at least better). I went with the pancake box for ease of installation and because my attic access is extremely difficult to get into... Trying to do everything from below if I can.
1 - 7 of 7 Posts
