1 - 20 of 30 Posts
Hi,
Im working a panasonic econavi hvac heater/ac
This is heater problem right now.
Its got two econavis in the room on 25 amp double pole breaker.
One econavi heater seems to be working fine. But then the other has power but no fan will run and it trips the breaker?
When does it trip the breaker?
At 3 years old it should have some sort of warranty left. Can you call the installer back?
I don’t know much about Panasonic other then they bought Sanyo out several years back and then removed them from the US market. Panasonic seems to be one of those minis where there isn’t a lot of technical literature about them.
Ok, if it trips the breaker you have a short.
Will it still trip if the other unit is turned off?
Use your meter to ring out the high voltage electrical components of the faulty head. You may find your short there.
What’s the model number of this equipment?
Discussion Starter · #10 ·
Okay thank you. I'm not going to be there till Monday to work on it though. I assumed I'd start with the wires that power the unit I don't even know what type of voltage I'm looking for am I looking for 120?I'm a beginner at reading schemetics.
Discussion Starter · #14 ·
Okay thanks I've actually got another extra unit of this and I'm wondering if I can just swap this blower motor part out and it will solve the problem. I'm new to knowing how to testing resistance. I know it's pretty simple but I just haven't done it.
Discussion Starter · #16 ·
Okay I just watched a little how to on how to test resistance I didn't know it was actually ohms also which it makes it confusing. Okay so I'm moving forward now I just need to know which points to probe with my multimeter too measure resistance on the blower motor? I'm also assuming I'm going to have to disconnect the circuit board that the blower motor is wired to? so that I can isolate it to test it properly for resistance?
1 - 20 of 30 Posts
