1 - 7 of 7 Posts
Hi,
How do people deal with this? Water has got into the windows and rotted out between the upright and horizontal board. The scraped out rot is probably 1/3 the total depth of the boards
I have treated this one with epoxy hardener/anti-fungal and was then going to fill with caulk in two stages.
Open to advice!
thx
t
Good elastomeric sealant at this point. You are probably still fighting a losing battle. Once the water gets in, it prone to keep doing it.
Thanks. I'm [hoping to] fix the water ingress problem too. I have a lot of windows like this. I'm pulling out putty, preparing/sanding/bogging if need be, epoxying, sealing, re-puttying, painting.
caulk gap, re-glaze window, oil primer, re-paint (x)2 coats 100% Acrylic Exterior Paint.
watch for weathering in future, and re-paint as needed. Otherwise forget and move on with life.
If there is punky wood you can use a wood hardener like Minwax wood hardener, and then follow steps as before.
When bad I just remove the mullions, fill the holes and glaze in a single pane of glass.
1 - 7 of 7 Posts
