I was afraid of thatjoecaption said:A whole lot of work...
Thanks againHome Depot and Lowes do not count.
That is the single best advise i have seen on these forums lolMay want to stop by your local real paint store and ask them what to use for a primer and paint. And no Home Depot and Lowes do not count.
Nonsense as usual.:furious: Joe is not a painter and is sometimes to quick to comment without thinking his responses.A whole lot of work but to get the paint to stay stuck there going to have to be degreased, stripped ( I would use a random orbital sander not a stripper)
primed with a bonding primer and two coats of finish paint.
Dude you said the same thing he did????Nonsense as usual.:furious: Joe is not a painter and is sometimes to quick to comment without thinking his responses.
You do not have to strip them so long as you remove any varnish that is chipping or flaking. You do have to degrease them and really clean them to remove any wax buildup that might be on them. You will need to fill in and out any surface imperfections.
Scruff the surfaces with fine grit sandpaper. Apply a quality bonding primer/underlay and then two coats of quality paint store finish.
If budget allows, think about upgrading the hardware.
Certainly did not! Here is his quote. We did agree on the need for primer and finish.Dude you said the same thing he did????
forgot this part..."( I would use a random orbital sander not a stripper)"Certainly did not! Here is his quote. We did agree on the need for primer and finish.
"A whole lot of work but to get the paint to stay stuck there going to have to be degreased, stripped..."
They do not have to be stripped if they are going to be painted.:thumbup:
Lost you bubba.forgot this part..."( I would use a random orbital sander not a stripper)"
Thanks for all of the responses. No stripping or sanding gets my vote!
Any recommendations on the degreaser or any additional cleaning supplies/method (or a URL outlining proper procedure & materials)? The guys at BM should be able to help with paint and primer recommendations, but I wouldn't put my nose up at any suggestions offered here.
Oh, and if anyone is willing to just come do the job...:whistling2:
Well, any farther and I'd be soaking wet! :boat:how far south east of Maryland are you?
I stand corrected. When I said no sanding, I was referring to sanding down to bare wood. Thanks for the heads up.I am going to jump in here
You DO need to sand everything after cleaning.
And thanks for the detail.Forget the deglosser
Clean with Dirtex
Lightly sand all surfaces with 120 grit paper
Apply a quality bonding primer( Cover Stain, Zinnser 123),Bin would be over kill
Apply 2 finish coats
Yes, but do they etch? I couldn't find that info on the quick search I did...and there are some pretty good no rinse tsp substitutes too.
:yes:... also take doors off and number all the hardware.set up a table and paint flat . i like a good purdy brush at least 2 1/2, i like a 3 inch brush ,cover stain primer and let dry over night,very light sand between all coats of primer and paint . im a s/w guy and for this i like pro classic warter bourn acrillic .for a pro these cabnets are a peice of cake :huh:,for a diyer if you take your time you can make them look very good:wink:how far south east of Maryland are you?
Clean with Dirtex
