Hi and thanks in advance.
We are now at the point where the new interior doors and door trim/baseboards are ready to be installed which has me probably overthinking this again ...
Both trim and bboards are a very plain style, basically a 3/4x3.5" for the doors and 3/4x5" for the baseboards..
Most of the companies I have talked to have told me the door trim is always slightly thicker (3/4) than the baseboards (1/2) so that the baseboards have something to end at without sticking out? Is this pretty standard as we wanted it all to be flush?
Regarding paint:
I have had one guy tell me he will take the doors, jambs and all trim to his shop, prime and spray then install and touchup as needed. He actually takes the door stop off in order to put the screws there at install then puts back on to hide all screw holes..
Another guy told me to get the doors installed and he will spray the doors onsite in a garage tent and handpaint all trim and baseboards before installation in the garage as well.. All the doors are 1 3/4 and weigh 100 puonds .. his comment was there is no way to prepaint the door and jamb without nicking it during install ..
Is there a preference here? Spraying seems to be a cleaner look but we will (with dogs, etc) eventually have to touch up with a brush down the road which would obviously not match the original spraying.
The brush guy told me unless you are 10" away and actually looking for brushstrokes, you will never see them when he is done and is just finishing a new construction home in the area I am welcome to go look at ...
Everything will be satin white if that matters..
If we go the handpaint route ... can someone recommend a paint I should have the painter consider ? We have all the paint comanies for the most part (orange county, ca.)
Thanks and any advice is appreciated.
Regarding paint:
