1 - 13 of 13 Posts
I'm doing a bathroom remodel that started off as just crown moulding then the wife got involved. :no:.
Anywho, the builder put a 6" high white marble surround around the whirlpool tub. the rest of the wall is some of the ultra thinned flat Monarch paint over rolled on textureing. The last time I had the three kiddos on the tub they had a great time spashing water over the backslash onto the walls. This cause the texture to stert buckling and pealing from the walls. when I pealed off the texture that was pealed, it didn't look like the builder used green sheetrock. I vinyl spackled where the tecture came off then thinned some out and rolled it to try to match it original texture. :laughing:
I'd like to paint this with a paint that can stand up to some occasional splashed from the kids and not let water soak through to the textureing and drywall. I know the watered down flat paint the builder used was like a spounge for water but I still want something on the flatter side of eggshell.
Recommendations?
· paper hanger and painter
Recommendations?
No such critter
From you're description, it sounds like improper drywall to begin with and then it gets worse.If it were me( and I could not redo the sheet rock properly) I would oil prime and apply a couple coats of at least an eggshell finish from a real paint store, making sure all was completly dry between coats and after painting
· Member
I just read someting about not being able to use BIN over Latex. Is that true. That would cause a problem with my current walls that have latex paint on them.
I've never heard that Dan. I quickly scanned the TDS for BIN and it makes mention of use over glossy painted surfaces w/out sanding, but makes no qualifications as to latex or oil. It makes no mention anywhere of not using over latex. I knew it wouldn't but just wanted to make sure.
Bin is just fine over anything u can think of. I second it's recommendation or maybe some Zinnser Coverstain Oil. You really want to try and block moisture from getting to the drywall and popping off the texture/paint. Follow with 2 coats of SemiGloss.
Reactions: jsheridan
Actually, Ben Moore makes Aura Bath and Spa, and it's a matte finish, which is between flat and eggshell. B/twn that and BIM as a primer/basecoat you should be watertight.
Would you put that on you're walls with kids splashing in the tub?:eek:
I know I would'nt. It is fine paint but IMO not good enough for this situation
· Rubbin walls since'79
Here's a thought- just around the splash area use a clear coat. If you want really flat and are oK to spend a buck to get it, use Modern Masters dead flat acrylic clear. Most other low sheens are really not that low- but it would seal the area. It will slightly darken the look also.
I've done this around sinks, particularly in laundrys.
· Member
Chrisn, if it's spec'd for steam, it should be fine for splash, as steam is harder on finishes than water in that sense, permeability. If it was a dark color, maybe not, but a light color I think would be fine. It may be a matte finish but it's a different formulation from Regal Matte. Brush's suggestion could work too. I've done the same myself when doing deep bases in baths/showers. BM has a flat clear in the super spec line, and I found that looking for Modern Masters.
1 - 13 of 13 Posts
