I am wanting to refinish my currently stained wooden stairs. My first hope was to be able to sand them down to bare wood and restain them. I quickly figured out that due to the ridges in the wood I would end up compromising the wood too much and coat my entire home in dust so I’ve since relegated to painting them. They did have a fairly heavy coat of lacquer on them which I have stripped/sanded off to some degree.
I had read somewhere previously that as long as you roughed up the finish you could use a floor paint over top without having to prime. Is that true? I’m worried because in some areas I am already at bare wood and others not so I’m assuming I will need to prime it all and then paint?
It’s kind of mess right now so I just want to make sure I’m on the right track. If I do need to prime would I need an oil based primer instead of water? Would floor paint be a best bet? And what type of lacquer/top coat would be most durable?
Thanks in advance!
Thanks in advance!
