1 - 6 of 6 Posts
Too Short? Cut it Again!
Depending on how wide and deep the cracks you can clean them out thoroughly and then inject them with a variety of fillers. Epoxy works well but can get pricey. If the cracks are extreme you may have some structural or thermal issues you need to address to alleviate the cracking.
Resurface with a stucco repair mix from your paint or building materials supply store. A box store is unlikely to carry anything useful. You can also mix up stucco if you have a lot of cracks to go over. It is not hard to do nor is it expensive. All kinds of formulas online.
I find a large car wash sponge works pretty well blending in texture. Stucco floats and other tools work well too of course.
Obviously you need to prime/seal your crack repairs before applying your finish coat. Do not race things between primer and finish paint coats.
Sherwin Williams sells a stucco patching compound designed for use under its SherLastic stucco finish. If the cracks are not too deep, the SherLastic itself will bridge the cracks. True stucco paint is the way to go if you have unstable surfaces, it has elongation qualities that are superior to traditional paints. Take some photos of your surface to the store and ask what grade of product you need in patch/finish for your situation.
And I forgot to mention. Pay close attention powerwashing stucco and watch the pressure setting or you will create problems. Do not try to use the powewasher as the primary means for crack prep or you will be sorry!
Realize this thread is about 8 months old, but I'm glad someone brought up this topic. My home has stucco on the front side, and will need some repairs, where my wife and I pulled a plant that growing up on the stucco. The plant was very sticky and took off part of the stucco finish, leaving a poor look.
Information here will be good to look over when fixing repairs and painting over the area.
1 - 6 of 6 Posts
